OK I'll bite.
Alaska is only bigger in size, including NON-liveable area and water. And apples to apples Alaska is not 84 times, that's laughable, larger it is only 2.5, and even then this is TOTAL unliveable area of Alaska compared to Texas which is 100% liveable.
Now if you take out the amount of water that is calculated into both Alaska is barely 2 times as big, but this is still including the NON-liveable areas of Alaska.
I could not find the data on the liveable area of Alaska, but when I do I will post it. Texas is bigger.
And yes, you ot me on a few spelling mistakes.
Whatever.
I am not following the whole Sunshine state thing.
I WAS referring to the fact that Florida is not considered a Southern state, more of a East Coast state. That's all.
Cool your wood and your contentions.
It was all in good fun, but we are still the biggest State no matter how you cut it.
If we did leave a large portion of Countries Energy companies would be here along with a ton of the technology based companies in the country.
You should do some research on just how many F500 companies are in Texas.
I believe the largest entity in Florida is FEMA.
But then again, as you have already proved, I know nothing.
