1 - 9 of 9 Posts
I have a 99 Sierra 1500 and i went out to start it the other day and i got nothin. All the Acc. came on but when I turn the key, I don't even hear the Solenoid on the starter engage. I heard the solenoid the first few times i tried it but after a few attempts, that stopped as well. I tried jumping it and got no where so i dont think its the battery. I tried changing the relay out but that didn't do anything. Can't find a fuse to check it. I think its a line fuse but i'm not sure.
The only reason i don't think its the starter itself is because it wasn't acting up at all before this. its like 30 degrees and under here and before the other day it started for me perfectly every time. It went from perfect straight to dead.
Any suggestions before I spend the money on a starter?
Thanks.
my first guess would be the battery or a loose battery cable...if that's ruled out, I'd say yes, it sounds like the starter.
if you can get to it, try wacking the starter with a hammer (don't laugh, it's worked for me:rolleyes:).
A good first place to start is to check battery cables to battery. Sometimes when loose they can corrode not allowing good contact. Also check the battery itself. I've done the hammer trick before and it works sometimes on a bad starter.
If its a bad battery connection do you think the Acc.'s would come on? Like maybe its good enough for that but not a good enough connection to kick on the starter? I'm at class now but when i get back i'll check the connections and the hammer trick. Thanks guys!
yes...just might not be getting enough juice to crank it over.
agree, check battery terminals first, take them off and clean them up. if it still doesn't start, could always take it off and take it to your local parts store and have them test it out
I just went thru this problem with the vette. Lights would come on, but as soon as I hit the ign nothing. I cleaned the connectors and coated them with dielectric grease.
1 - 9 of 9 Posts
