1 - 2 of 2 Posts
I just bought a 2012 rs 45th anniversary. I work really hard and love this car. There are minor problems I found after I bought the car. Can someone help me with minor fixes I can do instead of taking it to the dealership and paying way too much. It came with an owners manual but it doesn't cover 45th anniversary problems. Example. The door panels light up but the piece that goes across the dash does not. I looked online and it is supposed to light up. Not sure if it's a fuse, a wire, the light is burned out, or if I have to take the dash apart to fix this? Please help. This is factory original 45th anniversary with under 76000 miles. Ty
Super Moderator
I have seen the white strip on it, and it looks like it should, but I have never seen it lit up.
There should be bulbs or LEDs behind the plastic strip. They would all run off the same fuse. That strip should pop off, like a trim piece.
IF they're LEDs, they may not be replaceable.
You also said "problems" plural, and only listed one...
1 - 2 of 2 Posts
