This is for ADDING fogs to a CAMARO LS, or for those that have the big blinker bulb factory fogs.
These are aftermarket OEM Spec foglights for a 2007-2011 Tahoe (surprise, same part number as Camaro, usually at a lower price). They come in standard CLEAR or SMOKE. I opted for the SMOKE lens, which has a mirror like finish with a marginally darker lens.
The pop right in place and use the factory fog bezels, which are these part numbers:
LH: GM PART # 92194282
RH: GM PART # 92194283
They have the standard GM fog light connector and should plug into your harness if you already have fogs. LS owners, you either need to add wiring, relay and switch, or you can connect to your parking lamps so they come on when your lights come on - this is the way I will be connecting them.
I'll be doing a wiring video (I hope) this weekend or next weekend.
