1 - 4 of 4 Posts
2001 Camaro Z28
These specs are also found on the production spec sheet found here:
http://www.5thgen.org/forum/showthread.php?t=7001
Exterior Dimensions
Wheelbase: 112.3" / 2852mm
Length: 190.4" / 4836mm
Width: 75.5" / 1918mm
Height: 54.2" / 1377mm
Front Track: 63.7" / 1618mm
Rear Track: V6 - 64.1" / 1628mm, V8 - 63.7" / 1618mm
Curb Weights:
LS with Auto Trans: 3769lbs / 1713kg
LS with Manual Trans: 3780lbs / 1718kg
LT with Auto Trans: 3750lbs / 1705kg
LT with Manual Trans: 3741lbs / 1700kg
SS with Auto Trans: 3913lbs / 1779kg
SS with Manual Trans: 3860lbs / 1755kg
Weight Balance: 52% Front / 48% Rear
Interior Dimensions
Seating Capacity: 2 Front, 2 Rear
Front Headroom: 37.4" / 950mm
Rear Headroom: 35.3" / 897mm
Front Legroom: 42.4" / 1077mm
Rear Legroom: 29.9" / 757mm
Front Shoulder Room: 56.9" / 1444mm
Rear Shoulder Room: 42.5" / 1080mm
Capacities
Cargo Volume: 11.3 cu. ft. / 320L
Fuel Tank: 19.0gal / 71.9L
V6 Engine Oil: 7.6qt / 7.2L
V8 Engine Oil: 8.9qt / 8.5L
Curb Weights:
I don't understand why the LT Auto vs Manual is only a 9 lb weight difference, and the SS Auto vs Manual is a portly 53 lb difference!:confused:
And it must be a typo for the LS Auto vs Manual....the Auto is lighter.
I do like the nimble feeling of a balanced Front/Rear weight ratio....excellent for cornering!
Oil changes will be a little pricey at 7.6 and 8.9 qts since most of use only synthetic.:eek:
A good portion of that difference likely comes from the fact that the automatic used with the V8, the 6L80E, is quite a bit heavier than the 6L50E used with the V6. Also, maybe the Tr6060 used with the V8 isn't substantially heavier than the manual trans used with the V6. All in all I'd say those are reasonable assumptions.
I find it incredible that the V8 and extra weight of the SS equipment, brakes, exhaust?, only adds 119 lbs!
It's the AFM, it weighs 53 pounds. :D
Oh, and the SS weighs more, because it comes with Shunt's bigger brother, Shant. (as in, "you shant pass me in that boat, Mr. Challenger").
1 - 4 of 4 Posts
