One other thing Junkman... what is your current discount code for Adams? Going to place an order today!
You're confusing me my friend! I always place my coupon code at the end of my videos (The Junkman). Are you sure that you have really watched them???
Junkman - thanks for that. Couple of follow ups though.
Using the video you have on the Porter Cable and Adams products, you go through the 3 stages of polishing... the Orange, Green and Silver colored pads w/ matching polish. The Orange appears to be used RARELY, for serious paint repair, right? Does that then mean that the green and silver can be used weekly/monthly/semi-annually, etc.? Or, how do you gauge when to jump from the Orange to Green, Green to just Silver, etc.?
You've got the pad order wrong, something that I stress heavily in
this video series. Green is the most aggressive and the product that goes on that pad is called Severe Swirl Remover. Orange is next and the product for it is called Swirl and Haze Remover. There is no silver pad. The next pad is WHITE and the product for it is called Fine Machine Polish.
It also sounds as if you are still not understanding how this works. Let me explain it a different way.
Let say for example that you are 5'5" and weigh 500 pounds. A real lard azz. So, you decide to do something about it. You hire a nutritionist and go on a healthy eating and exercising regiment and slim down to 140 pounds. At that point, you are now at your ideal weight and look great.
Now at that point, are you going to turn to your nutritionist and ask, "So how often can I eat a gallon of ice cream, a 30 piece wing dinner and drink a keg of beer in one sitting?" Of course not! Those were the eating habits that caused you to become the lard azz that you were! Thus, what you want to do is stop living the way you did, which caused you to gain all that weight and start living a healthy life style. You don't loose 360 pounds and then starting eating like a cow again, right? That would be totally counter-productive to what you just accomplished. You obtain perfection and then maintain from then on.
Now let's compare that to paint correction. Let's say your paint is all jacked up from the crappy wash habit you have, the crappy towels you used and your complete misunderstanding of how paint is properly maintained. Then you get unplugged from the paint Matrix by the Junkman. You follow his instructions to the letter, buying all the necessary tools and supplies to make your paint perfect. After hours and hours of working on your paint, it is now flawless.
At that point, are you going to return to sending your car through the drive in car wash, start using crappy made in Chin towels to wipe on it again and return to washing the car with one bucket? Of course not, because you realize that these are some of the things that caused your paint to be jacked up in the first place!
THUS, you want to do a major correction of your paint ONE TIME and from that point forward, properly maintain it with all the practices that you see me do in my washing videos. If you do,
the damage that you will encounter will be so minimal, that fixing said damage will be a walk in the park! Thus, breaking out the green and orange pad should never be necessary again! The white pad/polish should be the only pad/polish combo that you should need to address the few tiny streaks of scratches that happen on occasion.
You majorly correct once, and then maintain from that point forward.
Now there will come a situation where a scratch will appear that may need to be addressed with the more aggressive pads but if you are using those pads and polishes all the time,
you are doing it wrong! That means that you are touching the paint improperly and thus, have not learned anything from my videos.
So how often can you use the green and orange pads? As much as you want if you don't like clear coat being on your car. If you cherish your clear coat, you will do all the things necessary to keep from having to break out those pads.
That's why I wash my car the way I do. The white pad and polish is so light, that you could use that combo daily and it would take forever to go through your clear coat. The other stuff is a lot more abrasive so I only want to use it
only when necessary.
Now in reality, the PC-7424XP ain't gonna remove a lot of clear coat no matter what product you use. However, you want to keep as much clear coat on the car as possible. Remember, every time you buff on the car, you're removing a certain amount of clear coat depending on the polish/pad you use.
So the phrase of the day is to
fix and maintain, not major fix and major fix and major fix and major fix... That why my paint looks like this, and there is not a DROP of wax on it in this picture. That's what proper polishing can do for your paint.
Does it make sense now?
