I am still waiting on a couple responses from a couple knowledgeable tuners, concerning next steps in tackling these unknown procedural steps forward. As of today, one possibility is to find a 2014 Camaro LFX and temporarily remove it's factory ECM, install my new 2014 GM, unprogrammed ECM and have my mobile programmer load a base 2014 program into it, along with the 2014 VIN.
Next step would be to have a performance tuner take the 2014 ECM and disable VATS and change the 2014 VIN number to my 2010 LLT VIN number but it needs to be DONE ON THE BENCH AND NOT IN THE CAR. (Still haven't verified that disabling VATS and changing the VIN can be done on the bench, as suggested)
Final step (hopefully) would be to roll the 2014 LFX engine/transmission up, next to my LLT, remove the (2) LLT engine harness plugs and plug in the LFX engine harness and see what happens. Obviously, from the pictures in the previous posts, I have the ability to do this without installing the engine in my LLT and if necessary have provided a way to even start and run the LFX on the stand. Codes and communications can then be verified and then proceed to resolve any issues that might remain. This is my daily driver vehicle and I cannot risk down time to install an engine that we don't know will even work in this LLT. This is why I am doing this project the way I am.
If anyone has any further input on this conversion/transplant project, PLEASE feel free to comment and/or assist. This is a FIRST of this kind in the 5th Gen Camaros. Uncharted territory. Hopefully, I will have more information in the coming days/weeks, as to if this is the correct procedure to follow or if another procedure should be tried first.
Footnote: As far as Global A, GM electrical architecture is concerned, it is generally agreed that this should not be of concern (although not written in stone) on this transplant. Global A began in 2010 to date on all Camaros. Google it to see what GM is up to. You will be totally amazed! This technology throws a monkey wrench into people changing and installing used body control modules in their vehicles in an attempt to repair issue themselves. You are at the mercy of the dealer!!!!! If attempted, the secret ID numbers in all the modules from the factory will default the vehicle useless and will not start until the car is taken to a dealer for proper repair. $$$$
