1 - 3 of 3 Posts
Gulf Mach 105
MACH 105 is a 105 octane unleaded racing fuel for street class racers. It features a tight distillation range and fast flame front that produces more effective throttle response and features lead-replacement additives that offer resistance to detonation. The performance of MACH 105 is best when used with supercharged or turbocharged engines. As MACH 105 is made with lead replacement additives therefore it can be used in engines designed originally for leaded fuels. MACH 105 contains no ethanol and has better lubricity than other leaded racing fuels. It will not harm oxygen sensors or catalytic converters. As with any gasoline, MACH 105 should be stored in an opaque tightly sealed containers where temperatures and conditions are stable. If properly stored the shelf life of MACH 105 is 2 years.
Unleaded and ethanol free
Specifications:
R+M/2 105
RVP: 6.3
Specific Gravity 0.75
Gulf Mach 110
MACH 110 is a 110 octane (R+M/2) unleaded racing fuel for racers who run high-compression/high-power engines. It is a good choice for engines with oxygen sensors and catalytic converters that could be easily damaged by a leaded fuel. MACH 110 features a tight distillation range and fast flame front that produces more effective throttle response and features lead-replacement additives that offer resistance to detonation. It is well suited for engines with compression ratios of up to 13:1. As MACH 110 is made with lead replacement additives therefore it can be used in engines designed originally for leaded fuels. MACH 110 is ethanol-free and has better lubricity than other leaded racing fuels. It will not harm oxygen sensors or catalytic converters. As with any gasoline, MACH 110 should be stored in an opaque tightly sealed containers where temperatures and conditions are stable. If properly stored the shelf life of MACH 110 is 2 years.
Specifications:
Research Octane 115
Motor Octane 105
R+M/2 110
Specific Gravity 0.78
GULF MACH 116
For Engine Applications that Require 110 – 116 Octane and Compression Ratios of Up to 15:1
Gulf’s additive lead replacement performs better than leaded fuels by producing more effective lubricity, while resisting detonation. The product reaches its stoichiometric value between 14.8:1 and 14.9:1 at idle/closed loop; and further, will not damage oxygen sensing systems or catalytic converters, while avoiding ethanol entirely.
116 Octane unleaded and ethanol free
Specifications:
Research Octane 125
Motor Octane 107
R+M/2 116
Specific Gravity 0.79
We do not ship fuel
Call 805-486-6644 for more info or PM
1 - 3 of 3 Posts
