1 - 20 of 20 Posts
I just had and update last night on autobook and this is what changed in the power tain tab
Prepared By:
administrator
2010 Retail Chevrolet Camaro 2dr Cpe 2SS 1ET37
TECHNICAL SPECIFICATIONS
POWERTRAIN - BASIC SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
ENGINE
Engine Order Code LS3
Engine Type HO Gas V8
Displacement 6.2L/378 CID
SAE Net Horsepower @ RPM 430 @ 5900
SAE Net Torque (lb ft) @ RPM 424 @ 4600
TRANSMISSION
Transmission order code MN6
Transmission Type Description 6-Speed Manual
Drive Train Rear wheel drive
MILEAGE
City EPA fuel economy estimate (MPG) - TBD -
Hwy EPA fuel economy estimate (MPG) - TBD -
City cruising range (mi) - TBD -
Hwy cruising range (mi) - TBD -
* Indicates equipment which is in addition to or replaces base model's standard equipment.
Report content is based on current data version referenced. Any performance-related calculations are offered solely as
guidelines. Actual unit performance will depend on your operating conditions.
GM AutoBook, Data Version: 144.1, Data updated 11/11/2008 11:29:00 AM
©Copyright 1986-2005 Chrome Systems Corporation. All rights reserved.
Customer File:
November 13, 2008 9:26:31 AM Page 1 Prepared By:
administrator
POWERTRAIN - ADVANCED SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
TRANSMISSION
Gear Ratio :)1)
First Gear Ratio :)1) 3.01
Second Gear Ratio :)1) 2.07
Third Gear Ratio :)1) 1.43
Fourth Gear Rato :)1) 1.00
Fifth Gear Ratio :)1) 0.84
Sixth Gear Ratio :)1) 0.57
Reverse Ratio :)1) 3.28
Clutch size (in) - TBD -
Final Drive Axle Ratio :)1) 3.45
ELECTRICAL
Battery 1
Battery cold cranking Amps @ 0 F - TBD -
Alternator
Alternator Amps 150.00
COOLING SYSTEM
Cooling system capacity - TBD -
Customer File:
November 13, 2008 9:26:31 AM Page 2 Prepared By:
administrator
PAYLOAD/TRAILERING SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
WEIGHT INFORMATION
Base curb weight (lbs) 3,860.00
TRAILERING Max Trailer Wt. Max Tongue Load
Dead Weight Hitch (lbs)
Weight Distributing Hitch (lbs)
Fifth Wheel Hitch (lbs)
Customer File:
November 13, 2008 9:26:31 AM Page 3 Prepared By:
administrator
CHASSIS SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
SUSPENSION Front Rear
Suspension Type Multi-Link Strut 4.5-Link Independen
Suspension Type (cont.) Double Ball Joint
Shock Absorber Diameter (mm) - TBD - - TBD -
Stabilizer Bar Diameter (in) - TBD - - TBD -
BRAKES
Brake type Pwr
ABS System 4-wheel
Front Rear
Disc Yes Yes
Rotor Diam x Thickness (in) 14 x 1.26 14.4 x 1.1
Drum
Drum Diam x Width (in)
TIRES Front Rear Spare
Tire Order Code QOO QOO
Tire Size P245/45R20 P275/40R20
WHEELS Front Rear Spare
Wheel Size 20 x 8 20 x 9
Wheel Type Aluminum Aluminum
STEERING
Steering type Pwr
Ratio :)1)
Overall 16.10
Lock-to-Lock Turns 2.50
Turning Diameter
Curb-to-Curb 37.70
Wall-to-Wall - TBD -
Customer File:
November 13, 2008 9:26:31 AM Page 4 Prepared By:
administrator
FUEL TANK Main
Capacity 19.00
Customer File:
November 13, 2008 9:26:31 AM Page 5 Prepared By:
administrator
DIMENSIONS - 2010 Retail 1ET37 2dr Cpe 2SS
EXTERIOR DIMENSIONS
Wheelbase (in) 112.30
Length, Overall (in) 190.40
Width, Max w/o mirrors (in) 75.50
Height, Overall (in) 54.20
Tread Width
Tread Width, Front 63.7
Tread Width, Rear 63.7
Min Ground Clearance (in) - TBD -
CARGO AREA DIMENSIONS
Liftover Height (in) - TBD -
Trunk Volume 11.3
INTERIOR DIMENSIONS
Passenger Capacity 4
Passenger Volume (ft³) - TBD -
EPA Classification Compact
Seating Position Front Second
Head Room (in) 37.40 35.30
Leg Room (in) 42.40 29.90
Shoulder Room (in) 56.90 42.50
Hip Room (in) - TBD - - TBD -
Customer File:
November 13, 2008 9:26:31 AM Page 6"
I believe octane5go said that those are the numbers for the ls3 crate motor not the camaros' ls3...... Octane????
those look like camaro specs to me.
It's only like 8 horsepower, but it seems like a helluva lot more for some reason.
it's certainly better than 8 less HP.
the more the merrier.
HP...
The LS3 rating of 430HP is the same as the LS3 that currently is in the Corvette. The rating may change in the Camaro depending on the routing and style of exhaust that is used. With the Corvette with the optional exhaust you can get up to 436HP.
A New Camaro, Excellent!
Corvette guys will be butthurt and just not understand how in the world this is possible.
As if the 422hp rating wasn't the same as 430...
Might as well make it 500hp.
I think most GM performance enthusiats knew and accepted that eventhough the LS1 in C5 vettes were rated at 350 hp, and LS1 f-bodies were rated at 310 hp, it was the same LS1 engine, just underated in f-bodies. Many dynos proved this.
I would suspect they are using vette numbers, but whether its 422 or 430, its still the same LS3. But yes 430 does sound better. :)
Just browse Corvette Forum and see how many people are so clueless as to the ratings between the Corvette and Camaro (all generations).
I know. My poor ignorant bretheren. :no: Not all are knowledgeable performance automotive enthusiats.
To me it's a no brainer.
1 - 20 of 20 Posts
