1 - 1 of 1 Posts
Billet trailing arms for Camaro SS and v6 models. Crafted from billet 6061 aluminum for strength and beauty. These replace the factory, stamped steel, trailing arms and provide decreased unsprung weight and increased stiffness to improve suspension response and lower 60' times. They also include significantly firmer bushings to reduce suspension compliance, and reduce wheel hop. Designed using Finite Element Analysis to optimize strength to weight. Easy to install and require no permanent modifications to the car.
Product Highlights
* Crafted from 6061 Aerospace grade Aluminum
* Firmer bushings to reduce suspension compliance
* 27 percent lighter weight than the stock links
* Reduced unsprung suspension weight for faster suspension response
* Design optmized with Finite Element Analysis
If you have any questions or would like to place an order call 229.245.9045 ask for Todd.
1 - 1 of 1 Posts
