🚨NOW AVAILABLE🚨 Multicolor LED Boards for 16-18 Camaro SS & 17-20 ZL1 | Diode Dynamics
Diode Dynamics is excited to announce our new Multicolor LED Boards for the 2016-2018 Chevrolet Camaro SS or 2017-2020 Chevrolet Camaro ZL1 headlights and lower DRL! These OEM-grade replacement LED boards for your Camaro’s upper and lower DRL allow you to customize your headlights and lower DRL housing with thousands of custom colors at the push of a button!
Unlike other color-changing headlights or DRLs for the 6th generation Camaro, our Multicolor LED Boards were computer-engineered for perfect fitment right out of the box. Simply remove your Camaro’s factory upper and lower daytime running lights, and our color-shifting replacement circuit boards drop right in!
Featuring DOUBLE the number of LED chips as the 2016-2018 Camaro SS and 2017-2020 Camaro ZL1’s stock daytime running lights, our Multicolor LED Boards are the brightest color-changing lights on the market! Even in direct sunlight, these LED boards provide rich, vivid color.
Features:
Our upper and lower Multicolor LED Boards for the 2016-2018 Chevrolet Camaro SS and 2017-2020 Chevrolet Camaro ZL1 are available in your choice of either RGBW or RGBWA options.
Our Multicolor LED Boards for the 2016-2018 Chevrolet Camaro SS and 2017-2020 Chevrolet Camaro ZL1 are available separately for your upper and lower daytime running lights, or as a combined kit. Each kit includes everything needed for installation. The full RGBW Multicolor LED Board kit for your Camaro headlights and lower daytime running light includes:
Since installing our Multicolor LED Boards requires opening or “baking” your Camaro’s headlight and lower daytime running light housings, we recommend working with one of our authorized professional installers.
Fitment:
Diode Dynamics Multicolor LED Boards for the 2016-2018 Chevrolet Camaro and 2017-2020 Chevrolet Camaro ZL1 were designed, tested, and manufactured in the U.S.A, and are backed by our 3-year warranty!
If you have any questions, please don't hesitate to post, PM, or Email [email protected]!
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
Features:
- Computer-designed LED boards for the 2016-2018 Chevrolet Camaro SS and 2017-2020 Camaro ZL1
- Adds RGBW multicolor and amber turn signal function (RGBWA only) to DRLs
- DRL override feature to automatically switch to white while driving
- Smartphone control with Diode Dynamics Bluetooth Controller
- Constant-current, high-power driver modules.
- Engineered and assembled in USA.
- RGBW: Enables thousands of custom color options, as well as a pure white daytime running light.
- RGBWA: In addition to true RGBW color-changing, the RGBWA option features a separate amber chip for a brilliant amber flasher when turning or using your hazards! The RGBWA option for our Multicolor LED Boards also includes the optional DRL override feature, which automatically switches your daytime running lights to a bright white when your Camaro is put in gear!
- Four (4) sets LED boards, upper and lower
- Four (4) waterproof drivers
- Two (2) RGBW Extension wire
- Eight (8) Nylon Washers
- Two (2) SolidState Relay Harness
- Two (2) Battery Input Wire
- Twenty (8) T-taps
- Installation guide
- Four (4) sets of LED boards, upper and lower
- Four (4) JST pigtails
- Two (2) RGBW extension wires
- Two (2) DRL Power Wires
- Two (2) Add A Fuse Harnesses
- Two (2) SolidState Relay Harnesses
- Two (2) Battery Input Wires
- One (1) zip tie
- Twenty (20) T-taps
Fitment:
- Fits all 2016, 2017, and 2018 Chevrolet Camaros with premium headlights, and 2017, 2018, 2019, and 2020 Chevrolet Camaro ZL1
- Fits all trim levels including SS, 2SS, SS 1LE, and ZL1
Thanks for looking!
Jake H.
Diode Dynamics
