1 - 20 of 39 Posts
this is my current build on my 87 iroc. been working on the car for about 5 years with the old tuned port set up but i decided to ditch all the maintnance and break downs and go with a lsx conversion with a 06 gto tranny that was adapted to my sbc. ditched the old school dash and went with a complete 02 dash and even got my FUEL gauge to work!!!
Engine was off 02 SS with 50k miles included
LS1 accessories power steering pump, TB, etc
New alternator
New seals
Port and polished TB
sent in oem harness to lt1wiring
Standalone extended Wiring harness and ECU
with basic tune
used
4th gen tank
modded feed return and evap
255 walbro fuel pump
06 GTO ls2 MN12 tranny and bell housing
06 GTO ls2 starter
LS7 clutch kit
New slave cylinder and master
Pro 5.0 short shifter
SPOHN LSx motor and tranny mounts
06 GTO CAI
C5 valve covers
MSD wires
Catch can
Gatorback belts
Summit aluminum radiator
Stock dual fan set up
Steel braided fuel line and Adapter Fittings
Auto meter adapter fittings for oil pressure and temp
TB Cable Non-TCS
02 SS ebony dashboard
Fuse relay box for ignition and 12v source
Switch breaker bar for ignition power
some small suspension work form the past
Still running the 4th gen rear drive train
3:42s and alum. Driveshaft
my process went from dropping in the engine pacing it butmostly workin on the dash .. cluster and electrical.etc
the last part was the harness and whole lots hours sodering and wiring!!!!
to start off heres the car
Discussion Starter · #2 ·
prepping the engine bay.
I started off by removing most of the wiring. Me and my brother have already experienced a ls1 swap in the past his his 3rd gen.
After hours of working on his car I gained a bit more experience and my set up was a bit more organized..
My engine was far gone I was ready to start prepping the engine bay for a better quality look.
My previous set up consisted of a cammed 350 mated with McLeod bell, mn12 GTO tranny and 4th gen rear differential
My intentions is to build a reliable 80s performance vehicle with the LSx drivability performance, yet fuel efficient, with modern interior and able to say I built this car.
I used esi data output for all the schematics for the 4th gen wiring.
Im attempting to run the evap and a fully functional cluster.
The process took a few months the only problem I came across was using a ls2 bell housing and finding the right starter. After researching the least expensive starter was the OEM Mitsubishi starter for lsx goats.
I purchased the ls1 with a k member and brake set up off ls1tech member.
As well as the fuel tank and dashboard.
Small appliances were supplied by the local parts store
All the fuel fittings and adapters were from others online or summit
Al work was done by myself with help of my close friends
And soon enough need some exhaust work for the y pipe
i started off with dissembling the old dash . Cutting grinding and bending metal for a test fit on the new dash .
Soon moved on to the 4th gen vents these fall right on top of the 3rd gen unit.. Modded and cut for future usage.
After painting the engine bay I left it plain and simple.
Main red wires to control ignition supply.
the instrumental work was done with extending wiring and merging the 4th gen cluster plug mostly color matched
Discussion Starter · #3 ·
i used two power distrubution blocks. from the battery as the main 12v source and power with ignition.
before with tpi wiring
after with Spohn motor mounts in place.
using the ls7 clutch kit
Moved back to the engine and worked on the smaller components
Used autometer adaptor fitting for the individual gauges for my oil pressure and water temp. aside from the cluster .
Used a summit radiator and hoses from AutoZone to run the cooler routed back to the power steering pump unit fuel rail fittings and evap controls etc,
Here I used 90* swivel fittings from the local speed shop
As well as compressor fitting which I used to shorten the 4th gen fuel feed line
Discussion Starter · #4 ·
Over view of the 4th gen fuel tank
I extended the wiring from the evap canister module, and the sending unit up to the dash .a whole lot of wiring.
Re worked on the quick disconnects and added fuel hose with some good clamps. These fuel lines were routed up by the rear area united to the fuel filter and hard lines to the front on the engine bay.
I used the walbro fuel pump a few mods. And this is what it looked like with a opening in the cargo area for easy access sealed up pretty good.
Discussion Starter · #5 ·
Cut 2.5 inches off the filler neck to clear the fuel door
The sending unit harness extended sodered and united to the control plugs
Once I received my harness from lt1wiring . Couldn’t be easier.
Pictures below everything was test fit and included with the obd2 port, fan relay, fuel pump relay and extended 2.5 feet for easy installation
Just scaring u guys a bit.. jk a bit unorganized but wire loom can take care of this.
The rest of the wires on my cluster plug consisted off the signal off the harness vss, oil temp
cool project...good luck with it!
Discussion Starter · #8 · (Edited)
Somewhere along routing the wiring for the fuel I got lost. My odometer turned on and a lot of unnecessary light were on.
Within time ill take care of that
Car cranked over yet has to be tuned
I will currently be working on my exhaust fabrication due to the fact that I am using stock manifolds. o2 sensor bongs in place and maybe work with a 4th gen y pipe that I have.,
Current pictures of my main cheerfulness. Fully functional gauges and soon to finish off the rest of the missing pieces
the dash is pretty much complete.. i need some exhaust work.. y pipe fabrication.. a re tune on the pcm.. and brackets for after market seats. ..
if anyone know of any?.. not too quiet expensive...
ill get some more pics vid up with time..
youll be able to find them here
http://www.youtube.com/user/tpiterror
Great work!!!!!!!!!!!!!!!!!
I had 4th gen seat in my 92.
They bolted right up!
Most GM seat will fit in that car, you just have to remove your brackets and install them on the other seats, but the 4th gens will bolt right in.
Excellent write up and great looking 3rd Gen you have there, Mr. IROC. Good luck and please keep us informed.:thumbsup:
Discussion Starter · #15 ·
updates on the car..got an y pipe fabricated.. i matched up my brothers pcm with 42lbs injectors .. car runs smoooth!! .i need a fbody shifter cup to use my 4th gen shifter.. i am currently using the gto shifter which i dont like.
That's great news.....have you driven it yet, and are you able to verify proper air/fuels to make sure everything is safe?
Discussion Starter · #17 ·
im not driving the car as much as i want to .. i put about 60 miles this weekend... im waiting on my pcm . calibrated to my engine. i can tell by the gas mileage that it isnt matched up .. .. but works fine for now.. i swapped out to bigger injectors (loaners) but i will go back to my tune.. and working with the evap. in the future bigger injectors..fast intake..headers. suspension work.. this car now feels way lighter.. and pulls hard. ! !
just need to invest in some seat sliders .. .. to adapt onto the the vette seats..
anyone have anything in mind???
Discussion Starter · #18 ·
so far so good. Ive been driving the car. about 300 miles already. car idles good runs really cool. and rides better than before the car feels pretty light
my friends dad was able to fabricate my stock seat sliders onto my passenger vette seat.. il be attempting to do the same to the driver side.
here some snaps of her stance
That is awsome. I love the dash swap.
1 - 20 of 39 Posts
