1 - 18 of 18 Posts
I found these plugs that are homeless. Anybody know where they go? The first is on the Passenger side, near the strut tower. Second one is drivers side firewall.
Also, does anyone know what kinda fuses go in the radio spot on the fuse box?
Here ya go, this is for an LO3 but it should get you going on the right track:
http://goingfaster.com/spo/l03_electronics.html
The two sensors/things-to-connect-to that are near the passenger side strut tower are the VSS or the set timing connector.
The three sensors/things-to-connect-to near the drivers side firewall are the ESC module, AIR Solenoid, or the fuse panel.
I'll let you know what my fuses look like tomorrow, its raining right now here.
I would really appreciate the fuse panel pic. There is just nowhere to plug in those plugs...
Will do. Is your engine TPI or TBI? If it helps any, I've got a few guys unplugged myself. Never really bothered to figure out where they went, the car runs just fine. They might be extras from when they first put the harness on the car.
Discussion Starter #5
TBI. It's got a buncha gremlins. I tried putting a fuse in the domelight/third brake light spot and it blew out immediately.
Electrical isn't fun...I watched my buddy mess with a riviera for 2 hours trying to find out why his lights would turn on randomly...good times.
Discussion Starter #10
Looking at that diagram, I'm almost positive it's ECD3, Fuel Pump Relay. Whoever did the wiring rewired the fan. It's not outside the realm of possibility that they rewired the fuel pump too...Something tells me that whoever had the engine rebuilt and reinstalled went to the absolute lowest bidder. I think it was some redneck who didn't mark where everything went and decided he'd uh...*f** engineer a solution.
What happened to your left wrist? I can see a support device there... :confused:
Hmm...I thought the radio fuse was the one it's pointing to.
You might be right. I did have an aftermarket radio put in some time ago. They may have pulled the stock fuse. Can't imagine it being more than 10A for a stock radio though.
What size fuse did you put in there that blew?
Also, heres a wiring info sheet that I found a while back:
1 - 18 of 18 Posts
