1 - 6 of 6 Posts
Stock 2011 1SS. I was going home tonight and got on the highway, ran her up to 4k rpms as usual for my break in period, I've got about 650 miles on 'er, I have about 1/4 tank left, was going to get gas when I got back into town 25 minutes away... mabye that would have something to do with it???
P0442: This indicates a fuel vapor leak in the EVAP control system. It means a very small leak has been detected. - Did a fuel cap check, nice and tight.
P0454: Evaporative Emission System Pressure Sensor/Switch Intermittent. - Not sure what fuse this is... should I check it?
P0464: Fuel Level Sender Intermitten. - Fuel sender? In the tank???
Any help? Is this something I should be worried about? I can clear the codes with my Predator... but dont know if I should look into this.... Like I said, brand new car, bone stock, no crazy driving, just get her up to 4k with a moderate foot, no tunes yet with the Predator... I dont wanna hurt my baby!
I wouldnt clear any codes unless i knew i was the cause, such as putting headers on. Is the car running normally? Check it again in the morning after it sits overnight. if it throws those codes again, I would take it to the dealer and let them handle it.
Completely stock.
I reset the codes before I went to work... nothing happened on the 20 minute drive here...
Codes come for a reason.. I would not clear them when they come back on, just schedule an appt at a dealer to get it looked at. None of those codes will hurt it to drive it.
Discussion Starter #5
Yeah :-\ it's been fine today, drives the same... I have an appt next tuesday to get some detailing done, maybe they can look at it then...
Hopefully the codes will come back, if you cleared, there is nothing they can see if you take it in.
1 - 6 of 6 Posts
