1 - 20 of 75 Posts
OctaneZ28 added a nice feature to our site. It's a Reputation System that allows our membership to give 'rep points' to other members. Reputation can be given by a member who feels that the post was beneficial, either through technical help, or just something that you found humorous. It's a way of saying 'thank-you' on a personal level.
The way to utilize the Reputation System is by clicking on the scale seen here in the bottom left corner of the member's post you found useful:
A drop down box will then appear with the default 'I approve' box highlighted. There will be a space to type a comment to the person you're giving reputation to.
The small green square under your post count is an indicator of accumulated reputation points. The more reputation points you have, the more green squares will appear. There is also a default 'quote' as you hold your cursor over the green squares. The quotes will change depending on the amount of reputation points. All reputation points and comments from other members can be viewed by clicking your User CP.
The Reputation System can be useful for others to see how much you have been appreciated for your help and positive posts here on the forums. I hope you find this new feature enhances your time here just a little more.
So.....if I take everyone out for DQ cones.......????
If you can get me at 5th gen SS for under MSRP, Ill give u rep. :lol:
And if its at invoice then you shall be blessed by ceiling cat.
  • Like
Reactions: Camaro Scotty
A little beta testing for ya...LOL If you give someone negative rep it still says "Thanks for adding Reputation to this user. May you be lucky enough to receive the same Reputation back in turn."
Meh, that and a couple of bucks might get you some coffee somewhere...not at starbucks though.
I'm talking about "rep" points. Too subjective to be taken seriously. I guess it gives some people a warm fuzzy, though.
Discussion Starter · #13 ·
REP TRADE!
Actually, Sluuug that would cancel out any positive benefits from the rep system and if it came to that, we would be better off without it. The way it's set up, we all start with the same rep points and those that merit more rep than others will rightfully acquire them.
The practice of 'rep trading' is the equivalent of 'post whoring'....both of which do nothing for a quality forum other than clutter up the boards. I ask that we all keep the system as it was intended to be used.
Thanks,
John
For whatever it's worth, the following is how we (I am a Mod on a Apple Mac Forum) do our Rep System. One note, we've been around a few years and have 39,000 members with 690,000 posts and 109,000 threads at time of my posting this. Point being, newbies are not allowed to Rep until they have met our requirements (time on forum and post count). Anyway, here's our FAQ that may or may not help some here?
Reputation System FAQ
What is the Reputation System?
The reputation system is very similar to the Karma system seen on other popular websites and forums (Slashdot.org, for example). Its purpose is to hopefully give users an idea of how respected, knowledgeable, helpful, gracious, etc., a person is. It is a system in which you rate your peers. It is a system that, hopefully, will make you think twice about your posts.
How do I give reputation?
There is a button in the lower left corner of each post. Click that button to display the reputation box:
After the rep box displays, choose positive or negative and always leave a comment so the person knows why you're giving them the rep.
Will the person know who left them rep?
No, not unless you tell them. You can only see the post and the comment for each rep point given, not who left it. Often though, people will leave their name in the comment so you know who it's from. However if you want to remain anonymous, you are able to do so.
How much reputation can I give out? Are there any limits?
There are quite a few limits in place to prevent minor abuse of the reputation system. Obviously there cannot be a flawless system, but these limits try to curb any intentional abuse. You must have 10 posts and 10 reputation points in order for your reputation to count on other people. Until you meet those requirements, your reputation will show up as grey dots (see below).
Everybody is limited to giving out 20 reputations per day; you cannot give the same person reputation until you have given reputation to 10 other people. This prevents friends from giving 20 reputations to the same person every day.
How do I see what reputation people have left me? How do I know how many rep points I have?
If you log into your Profile (linked from the top of every page), you'll see a list of the last 15 reputation points you received. In the upper right is your reputation score.
Someone gave me bad/good reputation and I want it removed. What can I do?
If you have a valid complaint about reputation, send a private message to any moderator with a link to the post you were given incorrect reputation. All complaints will be dealt with on a case-by-case basis, and changes to the reputation are not guaranteed.
What do the green, red, and grey dots mean?
A green dot indicates that you were given positive reputation. A red dot indicates that you were given negative reputation. A grey dot indicates that the user gave you reputation, but it counted neither positive or negative.
Why would a reputation point not count?
When a new user first starts out, their reputation does not count. There are a few factors that determine when their reputation should start counting. Some of those factors are the number of posts, the number of days they have been registered, and the number of reputation points that have been given to them.
In addition, even long-term members may not count if their reputation score is not at least 10.
When my reputation starts to count, do my previous grey dots start to count?
No, once a reputation value has been given (negative, positive, or neutral) the point values will never change retroactively. If you give a zero-point reputation, it will remain a zero-point reputation no matter how high or low your reputation point values become.
What are good reasons to leave positive reputation?
Reputation should be given to people who post meaningful, helpful, and thoughful posts. Any post that contributes to the thread in a positive way probably deserves positive reputation. This does not mean that you agree with what was said; the point brought up may be completely opposite to what you believe, but it may be a good point nonetheless, and worthy of a pat on the back. Giving positive reputation to someone because they are your friend and deserve to have a few more green dots next to their name isn't a good reason to give positive reputation.
What are good reasons to leave negative reputation?
Negative reputation should be given if the person is posting something that detracts from the conversation. If the post is rude, inappropriate, breaks forum rules, is not gracious, etc; these are all good reasons to give negative reputation. If you have a personal grudge with someone, it is not appropriate to give them negative reputation without reason. Giving negative reputation because you don't agree with what was said is not an appropraite use of the reputation system. People are entitled to their own opinions, and just because you don't agree doesn't mean the user was wrong or not contributing to the conversation.
Do I have to participate in the reputation system?
The reputation system is completely optional. But, by participating in discussion in our forums you are eligible to receive positive and negative reputation points from other users. You are not obligated to do so for others. However, the more people that use the system, the better and more reliable it becomes.
To the Admin here at 5thgen, feel free to use and or alter this if it warrants.
Thanks Octane!
I am in sooooooooooooooooooooo much trouble!
  • Like
Reactions: Taglane
Nice. I'll definitley be using them, but what can I rate 'down'? I love virtually every post as long as they're talking about loving the Camaro :lol:
Saying things like buying a Mustang or Challenger, Toyota is the best, modding a Civic makes sense, Anti-Camaro proganda, and praying to basement cat.
1 - 20 of 75 Posts
