1 - 2 of 2 Posts
My 2015 Camaro (purchased used) only came with one fob and a separate key. The fob is in really bad shape and I want to replace it. Can a new fob be programmed without a key. Don't need a key, just a fob. Thanx.
Super Moderator
For FUTURE questions:
  • Insert Existing Key
    INSERT a working flip key into the Ignition and TURN to the ON/RUN position (just shy of cranking engine).
    Wait for the security light to go out.
  • Remove Key
    TURN the flip key to the OFF/LOCK position and REMOVE it.
  • Insert NEW Key
    WITHIN 5 seconds, INSERT the NEW flip key into the Ignition and TURN to the ON/RUN position. The security light will turn OFF to indicate successful programming
    of the flip key.
    DIC will indicate # of keys programmed.
    If you hit nine (9) that is as far as you can go.
  • Exit Programming Mode
    REMOVE the key from the Ignition to finalize programming and EXIT Programming Mode.
  • Program Additional Remotes
    REPEAT Steps 1-4 for each additional key to be programmed.
  • Test Remotes
1 - 2 of 2 Posts
