1 - 1 of 1 Posts
Vendor
Despite the fact that from the very first sight all aftermarket custom hoods seem to look more or less the same, that's not quite true in the real life. For all 2016-2018 Chevy Camaros, we've hand-picked two truly unique applications that will make your muscle car stand out from the crowd. Available in different styles and materials, Amerihood SMS Style Functional Heat Extractor Ram Air Fiberglass Hood and AZ-Style Double Sided Hood by Anderson Composites boast unique features, allowing you to choose the most suitable application for your needs, wants and budget.
AZ-Style Hood by Anderson Composites is a perfect find for the fans of lightweight carbon fiber hoods. Manufactured to be as lightweight as possible it will improve your aerodynamics and impress with the ease of installation. For maximum safety, this hood utilizes OE hardware and will ideally fit into the OE connections. It is strongly recommended the use of a heat shield.
* Click on the pictures below to find more details:
Anderson Composites® AC-HD16CHCAM-AZ-DS - AZ-Style Double Sided Carbon Fiber Hood at CARiD
Fits: 2016-2018 Chevy Camaro;
Price: $1,322.10;
Availability: Manufactured - Ships in 7 to 10 days;
Strongly recommend the use of a heat shield;
Mounts with OE hardware;
Requires hood pins for safety reasons;
If Double Sided Carbon Fiber Hoods are not exactly the option, you would like to upgrade your vehicle's styling with, then SMS Style Functional Heat Extractor Ram Air Fiberglass Hood by Amerihood is your way to go. This is a first-rate quality functional hood equipped with built-in ram air tunnel to provide you with the maximum power gains and aerodynamic appearance. It comes unpainted and the installation typically requires preparation and painting. Professional installation is required.
Amerihood® CCM16AHSMSFHW - SMS Style Functional Heat Extractor Ram Air Fiberglass Hood (Unpainted) at CARiD
Price: $567.00;
Availability: Manufactured - Ships in 3 to 5 days;
Material: Fiberglass;
Comes unpainted;
All parts must be post cured and pre-fitted to the vehicle to be inspected before painting, such paintwork is the sole responsibility of the customer and person painting the part;
AmeriHood Durability Test:
https://www.youtube.com/watch?v=BAcE7yudIQU
Your Camaro deserves a makeover, get rid of the stock appearance with us! Pick a unique hood to turn your muscle car into the head-turning project with CARiD.com.
1 - 1 of 1 Posts
