1 - 6 of 6 Posts
2001 Camaro Z28
These are also available on the Camaro Specs PDF found here:
http://www.5thgen.org/forum/showthread.php?t=7001
All 5th Generation Camaros have 6 gears! :thumbsup:
V6 Transmissions
Hydra-Matic 6L50 - 6-speed automatic with TAPshift
1st Gear: 4.07
2nd Gear: 2.37
3rd Gear: 1.55
4th Gear: 1.16
5th Gear: 0.85
6th Gear: 0.67
Reverse: 3.06
Rearend Gear: 3.27
Aisin Warner AY6 - 6-speed manual
1st Gear: 4.48
2nd Gear: 2.58
3rd Gear: 1.63
4th Gear: 1.19
5th Gear: 1.00
6th Gear: 0.75
Reverse: 3.67
Rearend Gear: 3.27
V8 Transmissions
Hydra-Matic 6L80 - 6-speed automatic with TAPshift
1st Gear: 4.03
2nd Gear: 2.36
3rd Gear: 1.53
4th Gear: 1.15
5th Gear: 0.85
6th Gear: 0.67
Reverse: 3.06
Rearend Gear: 3.27
Tremec TR6060 - 6-speed manual
1st Gear: 3.01
2nd Gear: 2.07
3rd Gear: 1.43
4th Gear: 1.00
5th Gear: 0.84
6th Gear: 0.57
Reverse: 3.28
Rearend Gear: 3.45
...may not have to worry right off the bat about maxing out the transmission like I did with the 4L60. ...I wonder what the max hp rating on the 6L80 is though.
Good question. Best place to ask are the CTS-v forums. They have LSA's and 6L80E's. Something I just noticed though that's a bigger dip from 1-2 than the 4L60's. With 6 gears I would thought they'd be a tad bit closer.
1 - 6 of 6 Posts
