Hello, newbie here, I have a 2 week old (to me) 2010 Camaro 2ss and I have found a couple problems with it.
Number 1 both power outlets the one near the traction button and the one in the console under the arm rest seem to not be working. I tried using a USB charger in each to see if they would charge my iphone. the little light on the piece itself wouldn't illuminate. checked the fuses both 20s are getting power on each side.
Number 2 the USB port will not pick up on any USB thumb drives (tried three), nothing. Tried to 2 iphones (4gs and 6+), nothing. However, Bluetooth is currently working. I'm reading on other posts that the PDIM could be either not work correctly or is out of date. Could that be the case? Unsure of checking what software or hardware is current.
I am capable of replacing the parts if needed, would mean I would have to have it programmed correct? Before getting into throwing parts at it what are some things to look for first?
Thank you
Brian :smile:
Thank you
Brian :smile:
