BRAKES
Brake Pipe Fitting 16 N.m 12 lb ft
Brake Pipe Fitting - Master Cylinder 23 N.m 17 lb ft
Brake Pressure Modulator Valve (BPMV) Nut 8 N.m 71 lb in
Electronic Brake Control Module (EBCM) Bolt 3 N.m 27 lb in
Wheel Speed Sensor Bolt 9 N.m 80 lb in
Yaw Sensor Nut 9 N.m 80 lb in
INTERIOR FASTENER TIGHTENING SPECIFICATIONS
Front Floor Console Fastener 2.5 N.m 22 lb in
Front Floor Console Rear Cover Fasteners 2.5 N.m 22 lb in
Instrument Panel Assembly Fasteners 2.5 N.m 22 lb in
Instrument Panel Carrier Support Bracket Fasteners 2.5 N.m 22 lb in
Instrument Panel Compartment Door Dampener Fasteners 2.5 N.m 22 lb in
Instrument Panel Compartment Door Fasteners 2.5 N.m 22 lb in
Instrument Panel Compartment Door Latch Fasteners 2.5 N.m 22 lb in
Instrument Panel Driver Knee Bolster Energy Absorber Fastener 2.5 N.m 22 lb in
Instrument Panel Inflatable Restraint Fasteners 22 N.m 16 lb ft
Instrument Panel Tie Bar Assembly to the Vehicle Body 25 N.m 18 lb ft
Instrument Panel Tie Bar Assembly to the Vehicle Cowl 9 N.m 80 lb in
Instrument Panel Tie Bar Assembly to the Windshield
Frame and Plenum Panel 22 N.m 16 lb ft
Instrument Panel Trim Pad Fasteners 2.5 N.m 22 lb in
Instrument Panel Trim Plate Retainer Fastener 2.5 N.m 22 lb in
Instrument Tie Bar Assembly to the HVAC Module Assembly 9 N.m 80 lb in
Roof Console Fasteners 2.5 N.m 22 lb in
BRAKES
Brake Caliper Bleeder Valve 10 N.m 89 lb in
Brake Caliper Bolt - Front (L99, LS3) 60 N.m + 90 degrees 44 lb ft + 90 degrees
Brake Caliper Bolt - Rear (L99, LS3) 40 N.m + 90 degrees 30 lb ft + 90 degrees
Brake Caliper Bracket Bolt - Front (LLT) 40 N.m + 90 degrees 30 lb ft + 90 degrees
Brake Caliper Bracket Bolt - Rear (LLT) 40 N.m + 90 degrees 30 lb ft + 90 degrees
Brake Caliper Guide Pin Bolt - Front (LLT) 27 N.m 20 lb ft
Brake Caliper Guide Pin Bolt - Rear (LLT) 27 N.m 20 lb ft
Brake Hose Fitting Bolt 40 N.m 30 lb ft
Brake Rotor Bolt 10 N.m 89 lb in
Brake Shield Bolt 9 N.m 80 lb in
DOOR LOCKS
Front Side Door Lock Cylinder Clamp Screw 5 N.m 44 lb in
Front Side Door Latch Screws 10 N.m 89 lb in
Front Side Door Interlock Striker Bolt 10 N.m 89 lb in
Front Side Door Outside Handle Screw 10 N.m 89 lb in
Front Side Door Latch Striker Screws 25 N.m 18 lb ft
Front Side Door Interlock Striker Plate Screws 10 N.m 89 lb in
Rear Compartment Lid Latch Bolts 10 N.m 89 lb in
Rear Compartment Lid Latch Striker Bolts 10 N.m 89 lb in
DRIVESHAFT
Propeller Shaft Center Bearing Mounting Bolt 22 N.m 16 lb ft
Propeller Shaft Coupling Nut- Front 91 N.m 67 lb ft
Propeller Shaft Coupling Nut- Rear 91 N.m 67 lb ft
Propeller Shaft to Rear Differential Drive Flange Bolt 115 N.m 85 lb ft
Propeller Shaft to Transmission Output Flange Nut 97 N.m 72 lb ft
ENGINE COOLING
Air Conditioning (A/C) Condenser Bolt 6.5 N.m 58 lb in
Air Conditioning (A/C) Line Clip to Fan Shroud Screw 1 N.m 9 lb in
Auxiliary Cooling Fan Bolt 6.5 N.m 58 lb in
Brake Master Cylinder Nut 25 N.m 18 lb ft
Clutch Master Cylinder Bolt 50 N.m 37 lb ft
Coolant Air Bleed Pipe Cover Bolt (LSA) 12 N.m 106 lb in
Coolant Air Bleed Stud (LSA) 12 N.m 106 lb in
Coolant Pipe to Cylinder Head Bolt (LLT) 50 N.m 37 lb ft
Coolant Pipe to Generator Bracket Bolt (LLT) 10 N.m 89 lb in
Coolant Pipe to Thermostat Housing Bolt (LLT) 10 N.m 89 lb in
Electric Cooling Fan Blade Nut 7 N.m 62 lb ft
Coolant Recovery Reservior Bolt 17 N.m 13 lb in
Electric Cooling Fan Motor Screw 5 N.m 44 lb in
Electric Cooling Fan Resistor Bolt 5.4 N.m 48 lb in
Electric Cooling Fan Shroud to Plenum Bolt 6.5 N.m 58 lb in
Electric Cooling Fan Shroud to Radiator Bolt 6.5 N.m 58 lb in
Engine Coolant Heater (LSA) 50 N.m 37 lb ft
Engine Coolant Heater Cord Fastener (LSA) 10 N.m 89 lb in
Engine Coolant Heater Ground Wire Bolt (LLT) 12 N.m 106 lb in
Oil Level Indicator Tube Bolt 20 N.m 15 lb ft
Radiator Support Bracket Bolt 9 N.m 80 lb in
Thermostat Bolt (LLT) 10 N.m 89 lb in
Thermostat Housing Bolt (LLT) 20 N.m 15 lb ft
Thermostat Housing Bolt (LSA) 15 N.m 11 lb ft
Water Outlet Housing Bolt (LLT) 10 N.m 89 lb in
Water Pump Bolt (LLT) 10 N.m 89 lb in
Water Pump Bolt (LSA) 30 N.m 22 lb ft
Water Pump Pulley Bolt (LLT) 12 N.m 106 lb in
ENGINE ELECTRICAL
Battery Hold Down Retainer Bolt 22 N.m 16 lb ft
Battery Negative Cable Bolt (at rear compartment floor) 25 N.m 18 lb ft
Battery Negative Cable Terminal Nut 15 N.m 11 lb ft
Battery Positive Cable Nut (at the fuse block) 15 N.m 11 lb ft
Battery Positive Cable Nut (at the junction block) 15 N.m 11 lb ft
Battery Positive Cable Nut (at the starter) 13 N.m 115 lb in
Battery Positive Cable Terminal Nut 5 N.m 44 lb in
Engine Harness and Battery Positive Cable Harness
Retainers 12 N.m 9 lb ft
Generator BAT Terminal Nut 15 N.m 11 lb ft
Generator Bolt 58 N.m 43 lb ft
Generator Bracket Bolt (at the front of the bracket) 50 N.m 37 lb ft
Generator Bracket Nut (at the front of the bracket) 50 N.m 37 lb ft
Starter 58 N.m 43 lb ft
Starter Motor Mounting Bolt 58 N.m 43 lb ft
Starter Shield Bolt 5 N.m 44 lb in
ENTERTAINMENT & NAVIGATION
Communication Interface Module Bracket Bolt Screw 10 N.m 89 lb in
Front Floor Console Bolts 2.5 N.m 22 lb in
Front Overhead Console Bolt Screw 2 N.m 18 lb in
Radio Antenna Module Bolt 9 N.m 80 lb in
Radio Antenna Module Coil Bolt 10 N.m 89 lb in
Radio Control Assembly Bolt Screw 2.5 N.m 22 lb in
Radio Front Side Door Speaker Bolt/Screw 2.5 N.m 22 lb in
Radio Front Side Door Upper Speaker Grille Bolt 2 N.m 18 lb in
Radio Front Speaker Bolt/Screw 2.5 N.m 22 lb in
Radio Rear Speaker Bolt Screw 2.5 N.m 22 lb in
Radio Screw 2.5 N.m 22 lb in
Radio Speaker Amplifier Nut 9 N.m 80 lb in
EXTERIOR TRIM
Front Wheelhouse Liner Screw 3 N.m 27 lb in
Rear Wheelhouse Liner Screw 3 N.m 27 lb in
Rear End Spoiler Nut 6 N.m 53 lb in
BRAKES
DOOR LOCKS
DRIVESHAFT
ENGINE COOLING
ENGINE ELECTRICAL
EXTERIOR TRIM
