1 - 19 of 19 Posts
V8 (LS3, L99)
Headers:
GMPP shorty headers:
http://www.gmperformanceparts.com/sema/camaro/camaro_sitelet.html
$1000
part number: 92213295 http://www.gmperformanceparts.com/_res/pdf/GMPP_2009_Catalog.pdf page 164
Borla T-304 steel headers:
http://www.jegs.com/i/Borla/157/17249/10002/-1, http://store.summitracing.com/partdetail.asp?autofilter=1&part=BOR%2D17249&N=700+%2D237227+%2D59080+%2D59098+115&autoview=sku
$915.99
HPE Long Tube Headers:
http://www.hennesseyperformancestore.com/hpelotuhe.html
$1,895
Stainless Works A.:
304 SS headers with CNC mandrel bent 2" primaries and 3" slip fit collectors - headers only
http://www.stainlessworks.net/cart/product_info.php?cPath=475_476_529&products_id=1798
$990
Stainless Works B.:
304 SS headers with CNC mandrel bent 1-7/8" primaries and 3" slip fit collectors - headers only
http://www.stainlessworks.net/cart/product_info.php?cPath=475_476_529&products_id=1815
$990
Stainless Works C.:
304 SS headers with CNC mandrel bent 2" primaries and 3" slip fit collectors with high flow metal matrix catalytic converters and 3" lead pipes to fit Stainless Works Exhaust System.
http://www.stainlessworks.net/cart/product_info.php?cPath=475_476_529&products_id=1799
$1,450
Stainless Works D.:
304 SS headers with CNC mandrel bent 1-7/8" primaries and 3" slip fit collectors with high flow metal matrix catalytic converters and 3" lead pipes to fit to Stainless Works Exhaust System
http://www.stainlessworks.net/cart/product_info.php?cPath=475_476_529&products_id=1816
$1,450
Stainless Works E.:
304 SS headers with CNC mandrel bent 2" primaries and 3" slip fit collectors with 3" off road lead pipes to fit Stainless Works Exhaust System.
http://www.stainlessworks.net/cart/product_info.php?cPath=475_476_529&products_id=1800
$1,220
Stainless Works F.:
304 SS headers with CNC mandrel bent 1-7/8" primaries and 3" slip fit collectors with 3" off road lead pipes to fit Stainless Works Exhaust System.
http://www.stainlessworks.net/cart/product_info.php?cPath=475_476_529&products_id=1817
$1,220
Exhaust:
GMPP catback exhaust system:
with tips $950 part number: 92206992
without tips $750 part number: 92225672 http://www.gmperformanceparts.com/_res/pdf/GMPP_2009_Catalog.pdf page 164
GMPP Track Pack (off-road only):
part number: 92231570
Borla S-type series catback exhaust system + X pipe:
http://www.borla.com/applications/lookup.aspx/2010/Chevrolet/Camaro/SSStainless_Steel_Cat-Back_+_X_pipe/140280/
part #140280
$1,449.99
Borla Touring Series catback exhaust system + X pipe:
http://www.borla.com/applications/lookup.aspx/2010/Chevrolet/Camaro/SSStainless_Steel_Cat-Back_+_X_pipe/140281/
part #140281
$1486.99
Magnaflow Street Series:
http://www.magnaflow.com/02product/shopexd.asp?zone=all&id=121 2.5 in. system, Dual Split Rear Exit.
part number: 16579
http://www.magnaflow.com/02product/shopexd.asp?zone=all&id=123 2.5 in system, Axle-back, Dual split rear exit.
part number: 16581
Magnaflow Competition Series:
http://www.magnaflow.com/02product/shopexd.asp?zone=all&id=122 2.5 in. system, Dual split rear exit.
part number: 16580
http://www.magnaflow.com/02product/shopexd.asp?zone=all&id=124 2.5 in. system, Axle-back, Dual split reaer exit. part number: 16582
*8Hushpower Pro Series:
http://www.hushpower.com/product/80/Video%3A+2010+Camaro+SS.html?search_text=Camaro 3in. Pro Series "shorty" mufflers.
Corsa Exhaust system:
http://www.hennesseyperformancestore.com/coexsy.html
$1,450
Stainless Works exhaust system G.:
304 SS CNC mandrel bent 3" dual exhaust system with x-pipe, dual s-tube turbo mufflers, mirror polished stainless steel tips, and all hangers and clamps for easy installation. Fits factory connection point.
http://www.stainlessworks.net/cart/product_info.php?cPath=475_476_529&products_id=1801
$1,190
Stainless Works exhaust system H.:
304 SS CNC mandrel bent 3" dual exhaust system with x-pipe, dual chambered turbo mufflers, mirror polished stainless steel tips, and all hangers and clamps for easy installation. Fits Stainless Works Headers.
http://www.stainlessworks.net/cart/product_info.php?cPath=475_476_529&products_id=1802
$1,190
Diverters:
Noweeds exhaust diverters:
2.50" DIAMETER BOLT-IN SYSTEM FOR 2010 CHEVY CAMARO
http://shop.noweeds.net/product.sc?categoryId=13&productId=39
$950
Air Intakes:
GMPP Air Intake:
$450 part number: 92212302 http://www.gmperformanceparts.com/_res/pdf/GMPP_2009_Catalog.pdf page 164
Hennessey Performance Cold Air Intake:
http://www.hennesseyperformancestore.com/coairinkit.html
$395
Suspension:
Pedders Suspension:
http://www.peddersusa.com/products/21
Camaro Street I:
Camaro Front Radius Rod Bush, Item code: EP6577
Zeta Differential Mounts, Item code: EP1167
Zeta Rear eXtreme Sub-Frame Co, Item code: EP1169
price: $349.99 with package, $545.95 indidvidually
https://secure.merlinsoftware.com.au/peddersusa/Default.aspx?ProdCode=CAMARO+STREET+I
Camaro Sport Package:
Zeta eXtreme Adjustable Sway Bar Kit, Item code: 429006ADJKIT
price: $699.99 with package, $891.15 individually
https://secure.merlinsoftware.com.au/peddersusa/Default.aspx?ProdCode=CAMARO+SPORT+PKG
Camaro Street II:
Zeta Front Left GSR Strut, Item code: 9464L
Zeta Front Right GSR Strut, Item code: 9464R
Zeta Front Sport Coil 634mm, X2, Item code: 2954
Zeta Rear GSR Shock, X2, Item code: 9295
Zeta Rear OE HD Rear, X2, Item code: 2957
price: $1,299.99 with package, $1582.42 individually
Camaro XA Street Extreme:
Camaro Ext Xa Adjust Coilover, Item code: 160086
price: $1,799.99 with package, $2,836.68 individually
https://secure.merlinsoftware.com.au/peddersusa/Default.aspx?ProdCode=CAMAROXASTREET
Camaro Track II:
Zeta Front Control Arm Inner, Item code: EP6561
Zeta Rear Control Arm Lwr Out, Item code: EP7266
Zeta Rear eXtreme Sub-Frame Co, X2, Item code: EP1169
Zeta Rear Sport Coil 643mm, X2, Item code: 2955
Zeta Rear Toe Link Inner/outer, Item code: EP7267
Zeta Rear Trailing arm Inner, Item code: EP7265
Zeta Steering Rack/Pinion Mnt, Item code: EP2112
Zeta Upper Control Arm Rearwar, Item code: EP7263
price: $2,299.99 with package, $3,372.56 indidvidually
https://secure.merlinsoftware.com.au/peddersusa/Default.aspx?ProdCode=CAMARO+TRACK+II
Camaro XA Track Extreme:
Zeta eXtreme Adj Sway Bar Kit, Item code: 429006ADJKIT
Zeta Rear Lower Control Arm In, Item code: EP7264
price: $2599.99 with package, $3,582.38
https://secure.merlinsoftware.com.au/peddersusa/Default.aspx?ProdCode=CAMAROXATRACKEXT
Eibach Springs:
http://eibach.com/cgi-bin/start.exe/eibach/index.html
Pro-Kit (performance lowering springs):
part number: 38144.140 http://eibach.com/cgi-bin/htmlos.exe/041096.2.4286791283900022954
Sportline Kit (extreme lowering springs):
part number: 4.14438 http://eibach.com/cgi-bin/htmlos.exe/041096.2.4286791283900022954
Anti-Roll-Kit (Both Front & Rear Bars):
part number: 38144.320 http://eibach.com/cgi-bin/htmlos.exe/041096.2.4286791283900022954
Discussion Starter #2 (Edited)
Shifter:
Hurst Short Throw Shifter: http://www.gmperformanceparts.com/sema/camaro/camaro_sitelet.html
$300 part number: 92214388 http://www.gmperformanceparts.com/_res/pdf/GMPP_2009_Catalog.pdf page 164
Brake Systems:
*1Baer Complete System (Pro-Plus):
http://www.baer.com/products/complete/pro-plus.php
6 piston calipers and 13” or 14” slotted, drilled and zinc washed, 2 piece rotors.
*Will fit under 18 inch wheels.
Price: $1820.95 for complete front system, same for rear system.
Brembo Brake Upgrade:
front & rear
http://www.hennesseyperformancestore.com/brbrupfrre.html
$7,950
Packages:
*5MAST Motor Sports 2010 Camaro Track Packages:
http://www.mastmotorsports.com/page.php?Category=Engineered%20Accessories&Section=2010%20Camaro%20Track%20Packages&id=117
Fast - Stage I Stage Strip Package
"525 Flywheel HP"
• Mast L99 VVT Phaser series cam for auto trans. Camaro SS
• Mast LS3 Single Bolt series cam for manual trans. Camaro SS
• Mast premium nitrided valve springs
• Brings your Camaro alive with a nice noticeable lopey idle
Options and Upgrades
• EFI Live AutoCal Module with Mast Motorsports Calibration
• Muscle Rods long tube headers
• Muscle Rods exhaust systems
• Mast Black Label high flow fuel rails
• Mast Black Label roller rocker arms
Mast Motorsports recommends that every cam install using stock controller is accompanied by a calibration tune using HP Tuners, EFI Live, or equivalent software. Calibration is available from Mast Motorsports.
http://www.mastmotorsports.com/page.php?Category=Engineered%20Accessories&Section=2010%20Camaro%20Track%20Packages&id=114
FASTER - Stage II Track Package
"545 Flywheel HP"
• Provides a more aggressive idle and the power to get you down the track quicker
Options & Upgrades
http://www.mastmotorsports.com/page.php?Category=Engineered%20Accessories&Section=2010%20Camaro%20Track%20Packages&id=115
FASTEST - Stage III 12 Deg Competition
• Mast Black Label LS3/L99/L92 cylinder heads (rocker arms not included)
• The same gains as Stage II with the addition of Mast Motorsports Black Label LS3/L99/L92 cylinder heads for the ultimate in 2010 Camaro performance (cylinder head flow data and horsepower ratings coming soon)
Options & Upgrades
http://www.mastmotorsports.com/page.php?Category=Engineered%20Accessories&Section=2010%20Camaro%20Track%20Packages&id=116
Tom Henry Racing:
http://www.tomhenryracing.com/
http://www.youtube.com/watch?v=h4zWRTRvzN8
Fastlane Incorporated:
Stage 1 Camaro package
400rwhp 415rwtq
http://www.fastlaneincorporated.com/camaro.asp
Forced Induction:
Turbo Sysytems
*7Aerocharger:
http://hiperturbo.readyhosting.com/store/product24.html
coming soon.....
Super Chargers
*3Magnacharger:
http://www.magnacharger.com/
*9Techco:
http://www.techcointl.com/default.asp
Vortech:
http://www.vortechsuperchargers.com/index.php
Tunning:
*5Tune Time Performance:
http://www.tunetimeperformance.com/zen/index.php?main_page=index
Costum dyno tunes
Hennessey Performance power programmer upgrade:
http://www.hennesseyperformancestore.com/poprup.html
$600
Pistons:
Wiseco High Performance forged Pistons:
http://www.wiseco.com/Default.aspx
LS series pistons
http://www.wiseco.com/PDFs/ChevroletLS.pdf
*4Varam
*4MGW
*4Spin Tech
*2SSBC
*6AEM intakes
WARNING: Prices are subject to change. Check here for dealer prices on GMP parts. http://www.gm.oeaccessories.com/Home/
P.S. If anyone finds other upgrades for the Camaro please post the link and I'll edit this post.
Credit:
*1: XanthosV6
*2: FoxMarketingCars
*3: BlownChevy
*4: POWERFREAK
*5: Matt TuneTime
*6: Ken AEM
*7: VictoryRed08
*8: mmarcum
*9: Techco
anyone know when the dealerships might have some of these parts available?
Does anyone know who makes the GM Performance exhaust? I was told by the Dealer it was Borla but would like confirmation. My car is due here in Ca. this thursday and was thinking about having the dealer install before I take posession. Any help would be appreciated.
I've also heard it was Borla.
My ? is what is the best buy in headers short or longtube.What brandes and for the do it yourselfers. How long on installs.
Prevailing thought on this board seems to be longtubes. Almost nobody on the board felt the $$ spent on "shorty" headers was woth the expense.
As for install information and times, try the search button for more details.
Welcome to the site!
LT's are gonna make more power. Shorties are good if you want to keep the noise down and don't want to have to get tuned to keep the "check engine light" off.
American Racing and Kooks seem to be the choice for LT's. Doug Thorley seems to make nice Shorties.
Installation is pretty easy in the cars actually. plugs, wires, dipstick and the steering shaft (1 bolt) are the only things that need to come out. Can be done in your driveway if you know how to turn a wrench.
LONG TUBE is the only way to go. We use American Racing 304 stainless:thumbsup: Installs very easy compared to the 4th gen. Install time is not bad, no longer than a day and if you know what you are doing just a few hours.
If your dead set on paying your dealership to install the parts, just buy it and tell them to install it. Most dealerships will warranty any work they do and the parts if you purchase it from them. Simply put, they'll just tack on a 50-100% premium on the parts for warranty.
http://www.afabcorp.com/AFCO_Dynatech_USbrake/merchant.mvc?Screen=CTGY&Store_Code=Dynatech&Category_Code=2101CAMARO
Dynatech headers with high-flo cats in several fit configurations.
I've got the stainless 1 7/8" into 3" collector, then high-flow cats into OEM exhaust. $1300 Got mine at Autoanything.com @ $1195, then a zippy tune.
Dragstrip calculations show a solid 50hp gain.
They are quiet cruising, then start talking when you get into it.
Not disappointed.
+1 Best, reasonably priced headers on the market, perfect fit, easy installation. Can't lose. Matched with MBRP exhaust and you're good.
1 - 19 of 19 Posts
