1 - 9 of 9 Posts
So the gas engine is NOT connected to the driveline? This makes me ask some questions:
1) How big is the gas tank - how many gallons?
2) How long will it take the gas engine to recharge the battery?
(I assume that the engine will "turn on" each time the battery completely
loses it's charge)
3) How much of the "angular" look have they removed? - I thought that type of look was one of the appealing aspects of the Volt.
2001 Camaro Z28
In the Volt, the gas tank is about 8 gallons.
The engine does charge the battery, but only a little more than enough to make the battery work properly while the car is in use. This is done for maximum fuel efficieny, so it would take a long time for the battery to fully recharge while the car is in use.
While dormant, the battery fully charges in 8 hours, and uses about 1000 watts.
So assuming the cost of electricity is 12¢ per kWh, a full charge would cost only 96¢.
The overall look of the car is similar, it's just rounded instead of angular for better aerodynamics, and thus better fuel efficiency.
so the volt will work on the same concept that a diesel-electric train does. the gas engine just powers the electric engine that powers the car. so the gas engine barelly works at all... just has to make sure the battery has a charge. very good GM. If im not mistaken GM will be the first to employ this technology.
I think it may be a race to production between GM, Honda, and Toyota. Kind of like the moon race. Although, I think the Volt should be the first one out.
Disclaimer: Per recent posts from individuals stating their opinion as fact, I warn that this is just an opinion and is not based on hard facts or reliable information.:D
Yeah, except contrary to the moon race, this will ACTUALLY happen. :D
Oh, and that's also my opinion. :)
Wow, on a serious-er note, I could see solar panels to charge the batteries if you leave the car out, or even while you are driving during the day.
Hmmmm.....maybe I should start an aftermarket of Volt Panels.....
:lol: I like how that was your seriouser note, you making after market volt panels. On another seriouser note, they actually do make a paint that could work in place of a solar panel. I feel so green right now:D
1 - 9 of 9 Posts
