should fit. i have 22's with 305 30 on the rear and 265/35 up front.
uhhh, yes...scroll up to the top of this thread and contact the guy who started it.anyone know who sells custom 20 x 11 and 20 x 9.5 wheels for 2010 Camaro ss rs?
If you are referring to Boss Mustang wheels, they have a different bolt pattern according to Discount Tire at Home - Discount Tire DirectI'm wanting new rims..shiney ones for my 2010 Synergy GREEN MACHINE. Was thinking about staying with the 19" but maybe 20". Then I saw an add for used Boss rims w tires but 22. 265/35/22F and 285/35/22R says they work with the 35 series sidewall..I'm confussed, will they fit my Camaro without rubbing or any other issues? Hate to spend a couple grand and not be able to use them.. Thanks for any feedback I can get..
I heard u can go with a 305?Hey, I just picked up a 2010 2SS/RSI I believe the rear rims are 20x9 what are the widest tires I can mount on them. I am in the middle of installing a pro charger with the 9 lb pulley so I want to get some rubber back there. I love the look of the stock rims so I would like to keep them.
Thanks
Good morning, I recently saw a set of wheels I'm interested in. Im not sure the fronts will fit as they are 17 in. Attached are the specs. He claims his dad ran these on his 2010 camaro. Please advise . ThanksI will list tire sizes that are similar to OEM diameter, as this should help tire shoppers. The heights shown below are approximate, based on calculations. Refer to tire manufacturer's specs for the most accurate tire diameters. We recommend you stay within 0.5" (plus or minus) of the factory tire height in order to maintain accurate vehicle systems. This gives you an acceptable range of 28.2-29.3" diameters. Wheel widths shown are recommended, and only serve as a suggestion for proper fitment/appearance/performance.
Factory 2010 Camaro SS tires
Front 245/45-20 = 28.7" tall
Rear 275/40-20 = 28.7" tall
Recommended 18" Tires for 2010 Camaro
245/55-18 = 28.6" tall, 8.0-8.5 wheel
255/55-18 = 29.0" tall, 8.0-8.5 wheel
265/50-18 = 28.4" tall, 8.5-9.0 wheel
275/50-18 = 28.8" tall, 9.0-9.5 wheel
285/45-18 = 28.1" tall, 9.5-10.0 wheel
295/45-18 = 28.5" tall, 10.0-10.5 wheel
305/45-18 = 28.8" tall, 10.0-11.0 wheel
315/45-18 = 29.2" tall, 10.5-11.0 wheel
Recommended 19" Tires for 2010 Camaro
245/50-19 = 28.7" tall, 8.0-8.5 wheel
255/50-19 = 29.0" tall, 8.0-8.5 wheel
265/45-19 = 28.4" tall, 8.5-9.0 wheel
275/45-19 = 28.7" tall, 9.0-9.5 wheel
285/45-19 = 29.1" tall, 9.5-10.0 wheel
295/40-19 = 28.3" tall, 10.0-10.5 wheel
305/40-19 = 28.6" tall, 10.0-10.5 wheel
315/40-19 = 29.0" tall, 10.5-11.0 wheel
Recommended 20" tires for 2010 Camaro
245/45-20 = 28.7" tall, 8.0-8.5 wheel
255/45-20 = 29.0" tall, 8.0-8.5 wheel
265/40-20 = 28.4" tall, 8.5-9.0 wheel
275/40-20 = 28.7" tall, 9.0-9.5 wheel
285/40-20 = 28.9" tall, 9.0-10.0 wheel
295/35-20 = 28.1" tall, 9.5-10.5 wheel
305/35-20 = 28.4" tall, 10.0-10.5 wheel
315/35-20 = 28.7" tall, 10.5-11.0 wheel
Recommended 21" tires for 2010 Camaro
245/40-21 = 28.7" tall, 8.0-8.5 wheel
255/40-21 = 29.0" tall, 8.0-8.5 wheel
265/35-21 = 28.3" tall, 8.5-9.0 wheel
275/35-21 = 28.6" tall, 9.0-9.5 wheel
285/35-21 = 28.9" tall, 9.5-10.0 wheel
295/35-21 = 29.1" tall, 10.0-10.5 wheel
305/30-21 = 28.2" tall, 10.0-11.0 wheel
315/30-21 = 28.4" tall, 10.5-11.0 wheel
Recommended 22" tires for 2010 Camaro
245/35-22 = 28.8" tall, 8.0-8.5 wheel
255/35-22 = 29.0" tall, 8.0-8.5 wheel
265/30-22 = 28.3" tall, 8.5-9.0 wheel
275/30-22 = 28.5" tall, 9.0-9.5 wheel
285/30-22 = 28.8" tall, 9.5-10 wheel
295/30-22 = 28.9" tall, 9.5-10.5 wheel
315/25-22 = 28.2" tall, 10.5-11.0 wheel
Recommended 24" tires for 2010 Camaro
245/25-24 = 28.8" tall, 8.0-8.5 wheel
255/25-24 = 29.0" tall, 8.0-8.5 wheel
265/20-24 = 28.2" tall, 8.5-9.0 wheel
275/20-24 = 28.3" tall, 9.0-9.5 wheel
285/20-24 = 28.5" tall, 9.5-10.0 wheel
295/20-24 = 28.7" tall, 10.0-10.5 wheel
305/20-24 = 28.8" tall, 10.0-10.5 wheel
315/20-24 = 29.0 tall, 10.5-11.0 wheel
Hope that helps!
Tony 👍
